Stream SDS200
WZ8H
Marblehead, Ohio
Is there any way to stream my SDS-200 over the internet to like Broadcastify WITHOUT using a computer or Rasberry Pi etc.. By JUST using the Ethernet port. ?
Thanks.
belvdr
Yes you can do this. You’d have to port forward TCP and UDP 554 to the SDS200 and use a client like VLC to connect to the url using the external IP:
rtsp://External_IP/au:scanner.au
Keep in mind only one connection is allowed, so if you lose connection, you may not be able to reconnect until you power cycle the scanner.
jtwalker
BEE00.1E8-1.22 (or) BEE00.689-1.13
So you got a no and a yes from first two responses. I don’t think you could stream to a service like Broadcastify without a computer connected to the scanner (no), but you should be able to expose the scanner to the internet and connect with a client on your smart phone or remote computer (yes).
So I agree with both responses you got thus far.
belvdr
Crap I misread. I thought the OP said “not like Broadcastify”. Ignore my earlier response.
