Stream won't connect--audio 9
kb8zxe
Wakefield, MI
I disconnected my conventional feed to perform a reboot on sdrTrunk. It will no longer connect, the calls feed connects just fine. I plugged in my old raspberry pi backup for the feed and it won't connect either. I get this error on trying to run darkice manually DarkIce: TcpSocket.cpp:251: connect error [110] This feed is on audio 9. Anyone willing to try and disconnect and reconnect a feed on audio 9 or give me an idea what I might have broke. Thank you
n0esc
Signals, Secrets, Static
SE MN EN33
For a simple reboot/restart I doubt you actually broke something, but some of the magic gremlins may have escaped. Same happens to me where my linux based sdrtrunk node will run and reboot after a power outage just fine for months at a time... I touch it and it takes 30 minutes to come back, and frequently the wireless keyboard/mouse drivers fail to load or it gets feisty about the sdrplay usb port for no apparent reason. I now wait many months before updating anything just because I'm resigned to know it will be a battle every time.
Total stab in the dark but I'd just try a second full reboot, or even chance powering it off completely for a couple minutes giving everything time to disconnect and power down and bring it back up. It might just be a network or server side something not handshaking correctly and one side or the other thinks it's connected and the other is saying nope, not happening.
kb8zxe
Wakefield, MI
kb8zxe
Wakefield, MI
I appreciate the suggestions. I tried everything that I can think of without a solution. I tried rebooting a second feed that I have that is on a separate old school darkice pi image and upon reboot that feed would not connect. It is on audio9. I am going to go to bed and hope it's connected in the morning.
kb8zxe
Wakefield, MI
It was a dns issue, I could resolve audio9.broadcastify.com but the pi didn't like something. I defaulted my router and everything worked.
