SWEETGRASS302/BLUEWATER302
BC_Scan
Vancouver BC
Interesting, being trying to understand calls gins of units transiting British Columbia a USAF KC135R checked in at BLUEWATER302 , moments later when ATC answered back he became SWEETGRAS302 , same voice, very interesting . reg 58-0104 hex AE015B per ADSB
What you were probably hearing were waypoints or other ATC points and locations. Previously, that aircraft flew with RAMEN callsign out of Hawaii.
AirScan
It sounds like you are getting aircraft confused. On October 20th the K35R, 58-0104, was using the callsign FRESH 72.
SWEETGRASS is the callsign used by Iskwew Air. At the same time that 58-0104 was passing through the area there was a SWEETGRASS 302, a Piper Navajo (C-GPAK), operating between XQU to YVR.
I believe FRESH is a tanker callsign used when positioning fighters on long trips between bases, called Coronet Missions. Other noted Coronet tanker callsigns are ADOBE, BLUE, BOBBY, CABAL, CAFE, CLEAN, FIST, GOLD, PETRO, ROMA, RUMMY, VINYL. They use 2 digit flight numbers.
On these Coronet missions the fighters also use standard callsigns, noted have been CUBE, DORY, EMCEE, HURON, JEST, MAZDA, PINE, RETRO, TABOR, TREND, ZESTY. They also use 2 digit flight numbers in sequence. Eg first flight would use 11-12-13-14 ... and second flight would use 21-22-23-24 ..., etc.
As FRESH 72 was at FL370 they did not have any fighters in tow at the time, so probably returning from a previous mission between East Asia and Alaska. Typically Coronet missions will fly between FL230 and FL270 when they are dragging fighters.
You also might hear tankers on tactical missions, usually with Bombers. Noted callsigns for these missions have been ABBOT, DEED, FIAT, FLAM, HIFI, KECK, PICO, REALM. Also using 2 digit flight numbers.
AirScan
Around 10:45am PST today (Nov. 10) there was a coronet mission through the Vancouver area. Tankers were BOBBY 10 and BOBBY 11. Looks like they transferred the fighters between tankers just to the northwest of Seattle. Anyone catch any comms ?
BC_Scan
Vancouver BC
I saw that but did not hear anything , I have programmed UHF only air to air on a dedicated scanner with fx that are listed for refuel etc
I have been trying ...
AirScan
I'm not familiar with the Pacific frequencies. They have the eastern frequencies here. Not sure if they use different ones for the Pacific ? The fighters usually use their own frequencies for air-air between themselves. What frequencies are you scanning ? Might have to scan the whole band to find something. Let us know if you ever catch anything.
AirScan
Two KC35R reg 59-1508 +63-8000 (no callsign) on ADSB transiting BC right now hearing comms on 311.00
63-8000 was COUNT 98 and 59-1508 was COUNT 97. COUNT is a standard Fairchild 92/141 ARW callsign. 311.00 is their published Command Post frequency. So you might have caught them calling inbound with their ETA and any operational info. ? They don't appear to be flying in formation so maybe not much A-A, which might have been another frequency ? Other Fairchild callsigns I've heard are ASTRA, EARL, EXPO, ROOK, SQUARE, YETI, KNIGHT, SIERRA, ZAGS. Flight numbers 8x and 9x seem to be common when positioning.
