(Sorry for the long post). I have been successfully programming my 396xt and 996xtp2 for several years. Recently the Missouri P25 system has grown to the extent it is time to implement procedures to temporarily lockout and unlock neighboring counties due to the system just being too busy. If a TGID (Talk Group ID) is programmed, it will be received in SCAN ID mode when a system is active. Further is using SCAN SEARCH everything will be received. I would like to program neighboring county TGIDs so they will display but only when I believe something is going on there. For example a pursuit leaves my county into a neighboring county. My method has been to create a new P25 System with a new quick key assigned. I then added one transmitter and all the TGIDs for the neighboring counties. It seemed to work when I was at home on my base installed 996 but when mobile when I got out of range of the programmed single transmitter, the TGIDs text no longer displayed and I was using SCAN SEARCH. Can anyone think of a way to turn off unwanted TGIDs so I can use SCAN ID to limit unwanted traffic but still enable them when desired? 73
