T4Win & P25
b7spectra
EMS Dispatcher
Cobb County, GA
I don't presume that T4Win works with P25 9600 baud digital systems yet, or does it? I've had no luck with it on the new Cobb County (GA) P25 system, or does it need something different than the same feed I give it for analog?
You presume correct. It does not and won't until I get a proper release of UniTrunker out the door.
b7spectra
EMS Dispatcher
Cobb County, GA
I've been having some problems while running T4Win where it will just die on me (error shut down). Anything I'm doing wrong?
rjones
Atlanta
Mike
Do you have both the MSXML 3 and 4 sp2 parser installed? I had a problem like that for a while with T4Win, then I installed MSXML 3, then installed 4 sp2. Now it hasn't crashed for a while, unless I try and edit several talkgroups or radio ids at once without saving in between each.
