Talkgroup ID's for Public Safety Communications Service - Manitoba
ve4ear
Winnipeg, MB
Someone had posted a pretty accurate listing of the Winnipeg system but I can no longer see it in the database. It is 100% encrypted phase 2,
VA4JOE
When you check the database you have to browse by Metro Area instead of County...It is listed there...
ryan433pk
Saskatoon, SK, Canada
I was able to get eyes on a Highways Dept. radio in Winnipeg. I plan on using SDR in a few weeks when I return to identify all the talkgroups. The user noted they primarily use simplex
APX4000 portable
REGION 4
DAUPHIN HWY AES
ASHERN HWY AES
ENG REG4 AES
VEMA REG4 AES
HWYS PW1 AES
HWYS PW2 AES
HWYS SPX SIMPLEX
MCE AES
WATER CONTROL AES
OPS CEN AES
BC_Scan
Vancouver BC
FYI per IC, the simplex band plan for Canada is 775-776 MHz 6.25 or 12.5 or higher allotments spacing available. That being said, I found CBSA in Surrey using 771.24375 in simplex P25, contrary to what is printed
jets1961
I was in the Victoria Beach area this weekend and looking at DSD logs I am thinking Victoria Beach Police is TG 42063. I also think what was once the Zone 3-East is now Zone 1, TGs 40000 to 40016 but this is just an educated guess. TG's 40003,40004 and 40005 very active in this area. The TG's in the in the 40017 to 40036 were active to with 40017 to 40023 logged along with 40027 and 40033.
The active tower was 1.7 so it may have been across the lake in Gimli, the signal was low but I was in the pines :) .
ve4ear
Winnipeg, MB
I believe Site 1.7 is the Belair site. Likewise I believe Gimli is 1.28. The sites appear to be assigned alphabetically.
1.1= Altona
1.5= Beausejour
1.15= Carman
1.36= Jessica Lake
1.38= Lac du Bonnet
etc
I have seen Victoria Beach Police using Radio ID's 101450-101452. I have not been in that area to monitor but When the radios were in Winnipeg I see them affiliate to 42065. Seems like Brandon 911 patches together several of the rural police groups. with the main patch (supergroup) being 42063. If you check the activity on 42063 you will see Morden, Winkler, Altona, Cornwallis, Ste Anne and Victoria Beach.
When the RCMP were switching from Fleetnet to PSCS, one of the RCMP dispatchers on fleetnet was broadcasting in the clear. She told all units from xxxxxx detachment, they should now be on zone "East-A 04", or "Zone West-B 12". Each of the East, West and North areas have an A and B zone it seems.
I am guessing the 40003 to 40035 talkgroups are East A01-East A16 and East B01-East B16.
40036 to 40062 are the west talkgroups
40063 to 40090 are the North talkgroups
These are only guesses based on hearing RCMP units id in the clear on the Interagency talkgroups.
jets1961
It would make sense that they have a site in Belair. There are two towers on the east side of Hwy 59 in Belair. I will have a closer look and also attenuate my signal to see if I can confirm it is site 1.7 when out in that area again.
That is good information about the East A-B information. I wonder if the TG's are meant to cover smaller areas as the detachment have probably not changed? I have logs at home and will try to see what had the next most hit in the Vic Beach area, I will specifically check 42065.
I wonder if the old Z3-East would be divided in two East zones like you say East-A and East B but the psychical old Z3-East as two halves?
I notice that I have never had a hit on TG's 40001-3 either on my trip up that way or at home, so I bet the TG's do start at 40003 for whatever reason?
ve4ear
Winnipeg, MB
Regarding the RCMP TG 40000-40002, I have only ever recorded The Fire Commissioner affiliating and transmitting on 40000.-40002 as well as RCMP units). So my guess is 3 TGs for joint use (OFC/RCMP)
jets1961
My last post (#29) last sentence should say 40000-2, typo or dyslexia LOL.
Hemi204
Winnipeg Manitoba - Canada
Hey guys I have a question...this new P25 stuff is confusing for an old man that understood FleetNet quite well...
I'm out in the Whiteshell most of the time and I lose any comm's from the Airport even though it shows I have a signal...
Does P25 not work like FleetNet and piggy back off other towers? I don't really understand P25 Standard vs One Channel - The different band plans...do I choose one ?
I'm using a BCD396XT - If anyone has a FreeScan system file made they could post or take a screenshot of your system I would really appreciate it.
I probably set it up wrong.
Thank guys
ryan433pk
The users would need to be on the site you are decoding in order to hear the airport TGs.
If you use a program like DSDplus you can see which users are operating in your area even with encryption.
BC_Scan
Vancouver BC
This won't decode Phase 2 which is what It is Manitoba PCSC has switched to in the 700 MHz band. You would need to upgrade to a BCD 436HP or consider a SDR dongle (steep learning curve) but videos all over that show you exactly what you need to do.
You don't have to worry about the minutiae with a scanner. It will figure out the demodulation in order to hear.
I doubt you can hear CWYG from Whiteshell, and I doubt they would put airport t/g's all the way to that tower as its well outside of the intended range.
First consider upgrading scanner then go from there.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Thank guys
If you are outside of the sites that the airport talkgroups are affiliated to, and there are no radios affiliated to the airport talkgroups on your local site you are listening to, you will not hear the airport talkgroups.
Hemi204
Is it Phase 2 now? The description says its only Phase 1 at the moment.
I do get the airport in the city on my scanner in the 700 MHz band but you are correct...an upgrade is required
Gotcha, thanks for the info much appreciated!
ve4ear
Winnipeg, MB
No the system is Phase 1 only. Most of the airport talkgroups are not encrypted, a few are. All other provincial, federal, and public safety users are encrypted.
rusty15
Flin Flon Manitoba Canada
re: Manitoba Public Service new P25 system . I monitor the system with Pro96com. On the tower here at different times it will show Phase 1 and other times it shows Phase 2 . So I don't know if it is correct or not.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
If it is P25 Phase II capable, it lists as that in the database.
It could be specific to the talkgroups, perhaps. In Ontario, Toronto Paramedics mix P25 1 and 2
Paramedic Services - Zone A​
DEC HEX Mode Alpha TagDescriptionTag
1601641TEMS A1 NW SBA1 Northwest StandbyEMS-Talk
1603643TEMS A2 NE SBA2 Northeast StandbyEMS-Talk
1605645TEMS A3 SW SBA3 Southwest StandbyEMS-Talk
1607647TEMS A4 SE SBA4 Southeast StandbyEMS-Talk
161364dTEMS A5 NC SBA5 North Central StandbyEMS-Talk
1609649DEMS A6 SC SBA6 South Central StandbyEMS-Talk
1667683DEMS A7 AlertsA7 AlertsEMS-Tac
1669685DEMS A8 SpvrsA8 Supervisor and SupportsEMS-Tac
167968fTEMS Emerg RevertEMS Emergency Button Revert
