ve4ear
Someone had posted a pretty accurate listing of the Winnipeg system but I can no longer see it in the database. It is 100% encrypted phase 2,
When you check the database you have to browse by Metro Area instead of County...It is listed there...Someone had posted a pretty accurate listing of the Winnipeg system but I can no longer see it in the database. It is 100% encrypted phase 2,
Did you use Close Call or scan 700 to find this ?HWYS SPX SIMPLEX
I didn't have any gear with me at the time so I just took a video of him flipping through the zone.did you close call or scan 700 to find this ?
This won't decode Phase 2 which is what It is Manitoba PCSC has switched to in the 700 MHz band. You would need to upgrade to a BCD 436HP or consider a SDR dongle (steep learning curve) but videos all over that show you exactly what you need to do.I'm using a BCD396XT
If you are outside of the sites that the airport talkgroups are affiliated to, and there are no radios affiliated to the airport talkgroups on your local site you are listening to, you will not hear the airport talkgroups.Hey guys I have a question...this new P25 stuff is confusing for an old man that understood FleetNet quite well...
I'm out in the Whiteshell most of the time and I lose any comm's from the Airport even though it shows I have a signal...
Does P25 not work like FleetNet and piggy back off other towers? I don't really understand P25 Standard vs One Channel - The different band plans...do I choose one ?
I'm using a BCD396XT - If anyone has a FreeScan system file made they could post or take a screenshot of your system I would really appreciate it.
I probably set it up wrong.
Thank guys
Is it Phase 2 now? The description says its only Phase 1 at the moment.This won't decode Phase 2 which is what It is Manitoba PCSC has switched to in the 700 MHz band. You would need to upgrade to a BCD 436HP or consider a SDR dongle (steep learning curve) but videos all over that show you exactly what you need to do.
You don't have to worry about the minutiae with a scanner. It will figure out the demodulation in order to hear.
I doubt you can hear CWYG from Whiteshell, and I doubt they would put airport t/g's all the way to that tower as its well outside of the intended range.
First consider upgrading scanner then go from there.
Thanks for clarifying thatNo the system is Phase 1 only. Most of the airport talkgroups are not encrypted, a few are. All other provincial, federal, and public safety users are encrypted.
| DEC | HEX | Mode | Alpha Tag | Description | Tag |
| 1601 | 641 | T | EMS A1 NW SB | A1 Northwest Standby | EMS-Talk |
| 1603 | 643 | T | EMS A2 NE SB | A2 Northeast Standby | EMS-Talk |
| 1605 | 645 | T | EMS A3 SW SB | A3 Southwest Standby | EMS-Talk |
| 1607 | 647 | T | EMS A4 SE SB | A4 Southeast Standby | EMS-Talk |
| 1613 | 64d | T | EMS A5 NC SB | A5 North Central Standby | EMS-Talk |
| 1609 | 649 | D | EMS A6 SC SB | A6 South Central Standby | EMS-Talk |
| 1667 | 683 | D | EMS A7 Alerts | A7 Alerts | EMS-Tac |
| 1669 | 685 | D | EMS A8 Spvrs | A8 Supervisor and Supports | EMS-Tac |
| 1679 | 68f | T | EMS Emerg Revert | EMS Emergency Button Revert |
