talkgroups
J
jerryray
Guest
Anyone know how to program a cs700 on a repeater to monitor up to 15 talk groups?
I can only program 1 talkgroup.
So I have been making multiple channels with different talk groups.
Help
rescue161
KE4FHH
Hubert, NC
You have to make a scan list and then set them to auto scan, then point a talkgroup to the scan list. Then when you go to that channel, it will scan all of the channels that you placed in the scan list.
J
jerryray
Guest
OK, I am trying to digest what you said. The only auto scan I see is per channel basis. The you said "point a talkgroup to the scan list" I don't see where I could do that.
This the CS700
ORION_NE
Onawa, IA
If all the groups use the same frequencies, time slot and color code the following should work.
First you create the groups under Digital Contact.
Then under Digital RX Group Call you add the contacts to a List
Finally in the channel information you select the Group List you put all the members to.
J
jerryray
Guest
OK, so how do I use all contacts.
A local ham had me set the following.
callww
contacts3na
contatc2lcl
Is that correct for all?
Radiobern
San Leandro
You will need to program each talk group as a separate channel. Each channel must belong to a zone on the radio. You can then use the channel selector knob on the radio to select those different talk groups.
Here are some steps to follow:
First, create a zone for this repeater under "Zone Information", you can use the repeater callsign as the name.
Now, add each talk group under "Digital Contact" that you wish to operate on. For example, talk group 3 for North America.
Next, program each talk group into separate channels. Remember to include both Rx/Tx frequencies, color code, time slot and talk group.
Now, go back to "Zone Information" and add the channels you just programmed in.
At this point, you can upload this to your radio and you'll be able to operate on those talk groups on that one repeater. If you want to operate on different repeaters, just create a new zone for each repeater and follow the steps above. If you operate on multiple repeaters like I do, then you could have well over 100 channels in your radio, all organized by repeater or zone. Each zone can only have 16 channels and the radio allows for a maximum of 250 zones.
There is a scan feature, which the others have mentioned in previous posts. It doesn't work particularly well and many talk groups are PTT, so they are not always active.
This brings us to another topic, the difference between an "always on" talk group and "PTT". "Always on" means this talk group is always on, whether there is activity or not. If someone keys up, you'll hear it right away. "PTT" talk groups are activated on your repeater only if someone has keyed up. They usually have a timer and will last 5-10 minutes. If no one on your repeater has keyed up that talk group during that time, it will go back to being silent. Even if another user on another repeater keys up that talk group, you won't be able to hear it on the one you're using unless you key up again. Just think of the "PTT" talk groups as a party line or on demand talk group. It says silent until someone on your repeater activates it. This is all controlled by your local repeater owner. Hopefully yours will have information online like one of my local repeaters here: W6SRR | Digital Mobile Radio.
Now going back to scanning these talk groups. You won't hear any activity on these "PTT" talk groups unless they are active on your repeater. That means, if you scan a "PTT" talk group that hasn't been activated, you won't hear anything.
If you wish to scan certain talk groups, you will need to create a scan list under "Scan List". I have mine organized by repeater, so my scan lists will mirror those in the zone list. I left out all the "PTT" talk groups as they usually aren't active and you'll hear nothing.
Hope this helps, I see a lot of misinformation out there. I know this is new to everyone so we're all learning together. I currently have 10 zones and 124 channels programmed into my CS-700.
WA0CBW
Shawnee Kansas (Kansas City)
I might add that the "PTT" talk groups don't apply to the stand-alone repeaters. These repeaters act very much like an analog repeater. Also the "admit criteria" can be confusing to some.
BB
J
jerryray
Guest
Wow, lots to learn. I am getting there. Does the XPR7550 scan any different/better than a XPR7550?
