Tapping an PRO-2052 for ACARS
INDY72
Indianapolis, IN
Does anyone have a picture, or diagram tutorial of how to tap the RS PRO-2052 discriminator for decoding ACARS, and rail info vias software and PC?
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
INDY72
Indianapolis, IN
OK,... how do you run a line from the detector stage??? I have a friend who is wanting to do the mod so that he can use it for ACARS and CTC decoding.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Again, you don't. I'm not sure about CTC, but for ACARS, a nice clean patch from the speaker out will do the job. Just don't overdrive it. I haven't played with ACARS in ages, but I know the old version of ACARSD had something for this. That's all I did for my ancient PRO-2004 when I had one, and it worked like a champ
If your friend's soundcard on the PC is sensitive enough - not all of them are - the fixed level output at the record jack (if it has one - I'm not sure whether it does or not) would work. It will take a bit of experimenting to find out which works better. Often that's just an audio tap from just after the detector, but not always. It's worth trying.
73 Mike
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
I soldered to point 3 then drilled hole between power jack and 9 pin port for disc jack. Instead of cap I used a 1k 1/8 watt resistor at hook up to disc jack. Used a ground wire from jack to mount on 9 pin. Most discriminators have a cap.
