Ted Tones Out app for Android
LFD
Lindstrom, MN
Sorry if this has been talked about before but I could not find anything by searching the site.
A fellow Fire Fighter in our county called tonight to ask about this application. I could find VERY little info online other then the very basic info about the app itself.
According to what I could find, this app allows the user to "page" a Motorola Minitor pager if the user knows the 2 frequency's. I honestly do not understand how this could work but hopefully someone on here knows about it and could let me know.
If you google Ted Tones Out you will see the application and the minimal details of the app.
I will also post a cut and paste of the information.
Thanks for your help with this!
Chris
Description
Two-tone (Motorola Minitor®) sequential pager dispatch generator.
Allows user input of tone frequencies, tone durations and an optional voice dispatch message.
Use cases:
* testing pagers
* local dispatch where policy allows
* backup in case dispatch center fails
* backup in case repeater fails
bezking
On the Road
It looks like that app just generates and plays the tones out of the speaker or headphone jack; it doesn't actually transmit them over the air...
LFD
Lindstrom, MN
Thanks for the response.
I thought I had posted this message on the Motorola page but it somehow ended up on the Kenwood page. Not sure how I managed to do that but can this be moved to the Motorola page so it might generate further responses please?
Thanks,
Chris
KD2DLL
Rotterdam, New York
I have used this app multiple times before. Basically it just plays the tones. The only way it could activate a pager is if you placed a radio near the phone and played the tones. I have done this a few times to test my tones in my pager(Don't worry, I changed my pager and radio to a FRS frequency, that way it would only set off mine). I like the app, BUT, it really is dangerous.. I have heard of an instance where someone used this app(or something like it) and randomly started setting off peoples pagers.. The local FD assumed they used an app similar to this and most likely used one of those cheap Chinese radios that can key into any frequency. In the wrong hands, this app can be dangerous. But besides that, its a pretty neat little app. I liked using it to confirm tones by ear. Like for example I found a list of our counties tones on the wiki and I wasn't sure how accurate they were. What I did was I put these into the app one by one and played them. From listening to the scanner enough, you can just tell by ear if the tones sounded correct.
krokus
Southeastern Michigan
This app seems to have disappeared from the play store.
Has anyone been able to use the app with Lollipop? I do not want to "upgrade' to Lollipop until I can be sure this app will still work.
Sent via Tapatalk
rittmanfireman
Rittman, Ohio
I haven't been able to find it. Ill be looking for a good source to download it.
Chris
Description
Use cases:
* testing pagers
I have used this app. Basically you plug in the tones that you need, and how long they are to play. You hold the phone upto the radio, key the radio, and play the tones. This will then alert the corresponding pagers. I have tested it and it does work well...just use it responsibly. I believe they marketed it for emergency backup paging and so on.
portroyalbirdy
Central PA
It really is a shame someone had to ruin it for responsible users. I've also used it for testing pager programming (on a simplex channel, not used for emergency users) and its worked well! I have it on my old phone and boot that up to test but its a pain! A friend of mine said you could download the .APK file on the current device its on to a new phone. but I cant find the file
So Far Away....
Aww..Cummon now..Where for art thou are your inter-webs search skills...
Located in about 3 minutes..
Installed the APK on BlueStacks2....Installed & launched fine....
https://mega.nz/#!MQsmiBxT
DL Link is encrypted..PM for the key..
I already sent the key to a couple members..
So Far Away....
.the exact loc is irrelevant...
Oh...and like anything you DL..use at own risk...
Im not responsible if you brick your gear..
