Telequip Simcoe County NXDN and LTR Consolidation?
marsh325
I have been going through the Telequip LTR systems, and found a carrier for NXDN on the Barrie system. Wondering if the Barrie system frequencies were consolidated into the Edgar/Midland/King City NXDN system? Or does Barrie site runs independently?
mikewazowski
Forums Manager
Oot and Aboot
I'm still seeing an active LTR burst on at least one of the old Barrie LTR channels so I'd say it's still active.
marsh325
I see, I put it in my NXDN system I’ll take it out. Do you have any info on the Telequip Friday Harbour system? Not listed on Innisfil. I believe it’s two freq trunk, have yet to make it out there again.
mikewazowski
Forums Manager
Oot and Aboot
Didn't know they had a system down there. Found this in TAFL:
mciupa
ELBOWS UP, CANADA
Moderator
I'm here a lot
I get a signal from King City reliably and see it has Edgar, Midland and Site 12 as neighbours. Would Site 12 be Innisfil or perhaps Oro-Medonte?
mikewazowski
Forums Manager
Oot and Aboot
Could be although I think Oakville would be pushing it. *edit* yup, that's it.
Site 12 might be coming from Barrie. Control channel is currently 166.290MHz which show an LCN of 121. Reports neighbours of 1, 2 and 3 which would put it around Barrie/Innisfil. Didn't note much activity on it for the short time I was monitoring it.
I know Friday Harbour security uses PTToC so I doubt they'd be on it.
mapleradio
I wonder if they also run the ONQ network as well. All the consolidation is difficult to follow.
mikewazowski
Forums Manager
Oot and Aboot
I don't believe they run it but I know they do sell/rent radios on it. I would guess that if a customer needs coverage outside of the TDR network, they would put them on ONQ.
slicerwizard
Toronto, Ontario
Is this the network in question?
"Our Network Extends from Oakville all the way up to Parry Sound and has several Radio satelites in between to insure that you are always able to communicate when you need too."
Tell me your management isn't on the ball without telling me...
mciupa
ELBOWS UP, CANADA
Moderator
I'm here a lot
Miscapitilization, incorrect spelling and ending a sentence with a preposition. They should have used A I.
marsh325
Think it’s been updated already, but Innisfil is likely apart of the Telequip TDR. The radios at Friday Harbour were Kenwoods with a Telequip sticker. I was able to see one closeup and had it a control channel indicator. I saw the marina use similar units. It's safe to assume whole resort is on it.
mikewazowski
Forums Manager
Oot and Aboot
I've been watching the site and there's hardly any groups on it. Telequip, a car dealership, and a construction company seem to be the only users judging by the aliases. Not seeing any sign of anything Friday Harbour related and I already know Security is using PTToC.
I suspect they're on the 3 UHF repeaters I previously identified.
