TetraNetMonitor UI Experimentation
tomekjkp
Usa
Ok, I see that you have created the lines, I also tell you that you create more than two, since line 2 is used for tracking, in my case the use is deactivated after a short time. Well, at first glance I don't see the problem, you should show me if you have the dlls inside sharp and see how you activate the TNM puglin and hit set on top of a carrier so that it attaches to it.
I think I showed it well
1,2,3,4
FR33MAN
Hello everyone, in a few hours a video will be released on YouTube in which we teach how to create a plugin, in this case it is to launch the Tetra net Monitor (TNM) and the Tetra Trunk Tracker (TTT) from sharp sdr#, which I see it as very practical. I ask you to subscribe to the channel and watch the other videos of other projects in case you are interested in something and you will learn a lot at the programming level. Give it a like, if you don't know how to program, I will gladly give you the plugin so that you can use it for free.
N6ML
Hi, has anyone had a problem that after starting the computer and launching the application, no tuners are displayed and it does not collect data? It is also not possible to control it via remote start. I have already tried Tetra Network Monitor 1.1.2.1 and 1.1.2.5
I have tried SDRSharp from 1666 to 1727 and nothing, not even a twitch, before everything worked normally
My guess would be that Windows firewall is getting in the way. Maybe check that your network isn't considered "Public" (Windows Settings -> Network & Internet)
FR33MAN
You will find that change available in the latest download.
Latest version (v1.1.2.5) can be found in this post here: Download
Hello, as I always tell you, I am very grateful for your work, I always use TTT and TNM daily 24/7 and everything is perfect. My question is how could I send the TNM audio via virtual cable?
Many thanks for everything.
enCrypt
See my post #225 and related post #181 that I reference there
N6ML
I use a different approach from that referenced above (I think) on Windows 11...
  • Launch TetraNetMon.exe
  • Right-click on the speaker icon on the Windows taskbar (notification area?) and select "Open volume mixer".
    • Under "Apps" in the Volume mixer, expand "TetraNetMon", and set the "Output device" to your virtual audio cable.
  • (important) Terminate and relaunch TetraNetMon
That way, there shouldn't be any issue with system sounds, as you're not changing the default audio output device.
If you install TetraNetMon.exe in a different location (directory), you'll need to repeat the above, as Windows treats it as a different "App" (IIRC).
Marco192
Any suggestion on how to boost the output volume of TNM?
Everything is on max. in windows sound settings, but it seems that the volume coming from the TNM is just to low
MarkRegul
Could you please tell me how to add this plugin to the sdrsharp 1920 version, things have changed there?
thanks
N6ML
Plugin installation is a bit different from older versions - you have to create a subdirectory for each plugin instance under "Plugins" - named "Tetra1" thru "Tetra10", and place a copy of "SDRSharp.TetraNetMon.dll" in each subdirectory. The other files go in the top-level sdrsharp directory as usual.
MarkRegul
Thank you for your reply. Almost got it. But there is some problem with launching the TetraNetMon.exe file.
It won't start. I tried to run it as admin or change compatibility mode, but it doesn't work.
The file does not run under Windows 11. Strange, although a week ago everything worked.
N6ML
Shouldn't need to run as admin or in compat mode - at least I don't, on Windows 11 (now 24H2). Are you sure it's not already running, but minimised? Check for a "TNM" icon in your Windows tray (the task bar icon may be hidden)...
MarkRegul
I just run the file and nothing happens
romandocent
Hey. I need help. The Tetra Network Monitor plugin disables itself in SDR# every time after I hear a transmission. What am I doing wrong? SDR# version is 1920, TNM is 1.1.2.5., Windows 11
FR33MAN
Hello, do you mean that carrier number 2 is deactivated?
