The JNCR System
maus92
OCMD
I can only attest for two sites:
Should be +10 offset.
BM82557
Berkeley Co WV
View attachment 132442View attachment 132443
Same for me +10 --
Network: 580A0.005 ; JNCR Sysid 005
Bandplan #0: Base=380. Offset=+10 Spacing=12.5 BW=12.5
Bandplan #8: Base=380. Offset=+10 Spacing=12.5 BW=12.5 Slots=2
Site: 1.1 NAC=005 ; Raven Rock/Site R
Neighbor: 580A0.005-2.2
Neighbor: 580A0.005-4.4 ; Mt Quirauk
Neighbor: 580A0.006-1.1 ; Fort Detrick
Neighbor: 580A0.015-8.8 ; Camp David
Network: 580A0.015 ; JNCR Sysid 015
Site: 8.8 NAC=06B ; Camp David
Neighbor: 580A0.005-1.1 ; Raven Rock/Site R
  • Like
Reactions: dmi
GTR8000
NY/NJ Database Guy
BEE00
The band plan has been added to all sites in the RRDB.
dmi
Somewhere In, MD
Indeed. What is the meaning of "TDMA" in the band plan? The system is listed as P25 Phase 1..
P25 Channel ID Table
CH IDTypeBase (MHz)Spacing (KHz)Transmit Offset (MHz)
1FDMA380.0000012.5+10
9TDMA380.0000012.5+10
GTR8000
NY/NJ Database Guy
BEE00
What's with the TDMA? Is this to do with future upgrades?
That's how Harris set the system up. To date, no TDMA talkgroups have been identified as far as I know.
maus92
OCMD
The Raven Rock site (005-01-001) was reporting a neighbor site 005-02-002 using 385.025 as its cch. Didn't there used to be an entry for this site in the RRDB? It was theorized that this is a site used inside the mountain.
BM82557
Berkeley Co WV
Yes, it used to be in the DB, this is from 2018 --
dlwtrunked
that was back when I got into an argument with several that there was that Site 2 on the same frequencies. I heard both--using the same control channel with switching back-and-forth which site number I saw. It was disputed and apparently removed. I conjectured it covered inside the mountain.
ezdropper
Maryland
Probably been asked before, but I'm seeing talkgroups like below with 2 numbers on them, guessing they are just patches?
385.175000 Joint National Capital Region / Joint Base Andrews Unknown TGID:25173 9645 P25 1 25173 NFM 3 P25 Trunk
ecps92
Taxachusetts
What Software or Radio are you seeing this format in?
that will help in a more accurate reply
Since 25173 is shown twice, my assumption is that is the (TG) Talkgroup
and the 9645 might be the Radio ID (RID)
maus92
OCMD
9645 is a tg - it is used by older infrastructure / subscribers that are still in service after the NDW dispatch function was consolidated.
ecps92
Taxachusetts
hence asking what the OP was seeing it from. (Radio/Software) to get context
Guess it is a patch then between the old and the new ?
