TK-2180 Antenna Jack Replacement.
bcannon87
I just picked up this radio used and has been working great. I added a KRA-22 antenna. I noticed that it looks like the center conductor in the radio jack isn't sticking out as much as it is suppose to. (Please see attached photo.) Does someone mind posting a picture of there center conductor. If it does need to be replaced is there somewhere I can find instructions. And does the installation require soldering? Thank you all in advance.
cabletech
Puget Sound
The antenna jack is a reverse SMA connector. The whole thing is a part of the main frame and you will have to replace the frame.
Ordering the frame is very hard unless you are a dealer, it would be better to take it to a dealer and let them do the replacement.
ramal121
Lots and lots of watts
Calif Whine Country
Uh, no. It is a standard SMA male and by the picture I can see the center pin is broken off. Needs to be replaced.
Hardest part is getting the guts out of the case. Once you do that you'll see the connector is held to the frame with two screws. Take the screws out and lift it gently up, no soldering required. Installing the new one you'll see the bottom of the center pin will contact a gold finger piece down the hole. Just get it in right and reinstall the screws. Dab of locktite will help keep them in place.
East Coast Transistor | The Source For Original Accessories And Parts
Search part E04-0416-25
llu727
New Jersey
+1 for what Ramal 121 said. Its harder to get out of the housing than it is to replace the connector.
I would also double check and make sure that the broken pin piece isn't still inside of the antenna. Makes for a bad day if you screw the antenna on and break the pin again!!
bcannon87
Thank you all for the replies. Got the part ordered. Have a blessed day.
