Tk-260g Scan
vzfarms
ohio
I have 4 kenwood tk-260g's and I heard through the grapevine that they are capable of scan with the right version of programming software. Is this true and what version is that?
vzfarms
ohio
do I upgrade the firmware to 270G firmware?
somewhere else i saw that
n4xdn
Pickens, SC
TK-260G Scanning
Yes you will need the firmware. I thought that in addition you needed to program the 260g as a 270g via software but was able to do it as a 260K or M, on of the other euro models so it will do it as a 260g however you will always have to make your priority channel "channel 1" it will not do priority selected scan.
73's
kg4uad
vzfarms
ohio
I now have an issue with programming
I got the radios to program but started getting the bad connection message, now I cannot read the radios at all using KPG56D 2.10
I am using this cable
Kenwood Programming Cable KPG-22 KPG-4
It will start to read sometimes, make it through a few blocks, then stop
any ideas?
n4xdn
Pickens, SC
tk-260g scan
try "writing" the new software, not "reading" , it should tell you that the model type might be wrong and if you want to over right - click yes. see what that does.
kg4uad
