TK-272G Programming?
KD2DXF
Nobody
Anytown, USA
i have a used tk-272g Vhf, and its set on fire frequencies, i need to reprogram for my business frequencies.
i have downloaded the KPG56D software but i have a 32 bit system on my computer and the spftware is 16 bit. im not going to go out of my way to buy new USB cable for my laptop wich is windows 7 32 bit, if the program wont work, so any advise is useful. thanks :)
krokus
Southeastern Michigan
Wirelessly posted (BlackBerry8530/5.0.0.973 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
Is there a question that you have?
larry308
Gautier, Ms
272g
I should also add that to use the software that you downloaded, you will also need the access code that the Kenwood techs use to unlock it.
KD2DXF
Nobody
Anytown, USA
yes the question is will the 16 bit program work on my 32 bit computer
KD2DXF
Nobody
Anytown, USA
i got all that, ive been experimenting with the software, i just need to buy the cable, but i wasnt going to buy a usb cable for my laptop if its not going to work. thanks for the tip on the older computer
Res21cue
Res21cue
I bought a USB Cable on ebay for 12 dollars....works perfect for programming my 272G... Im using 32bit Win XP.
USB will work fine.
