TK3300 Programming Options
avguy
NY, NJ Shore
I just purchased a TK3300 on eBay to use at work.
We inherited 6 units from another part of the company already programmed, however nobody knows what the frequencies are.
(licenses are kept in the corporate office several states away)
From reading the manual it seems like I can make it "talk" when in programming mode.
Will a unit tell me how it is currently programmed in this manner or do I have to buy software and cable to read an already programmed unit?
ramal121
Lots and lots of watts
Calif Whine Country
If the radio is set up for it, you can use the wireless clone mode to copy on a per channel basis.
avguy
NY, NJ Shore
I just got the unit and charged it overnight.
When I turn it on all I get is a solid tone and flashing orange and red light.
None of the programming functions seem to work either.
The serial number tag looks a little odd to me.
Did I just buy a really good fake, or does it just need to be "re-flashed"?
ramal121
Calif Whine Country
This is one of those cross-over radios. What I mean is between a bubble pack job and a real business type radio.
They come default loaded with business band freqs and give you (the user) the ability to change those freqs by picking from a list.
With the programming software you can put in ANY freq within the band limits, and also disable the self program and clone feature. By what you describe, someone has already gone in and blanked the channels and disabled the self program mode.
Your only chance is to get it hooked up to a computer running KPG-120D software to get it back to the way the instruction book says it should be.
avguy
NY, NJ Shore
I just purchased two more and am adding them to my rental inventory.
I'm going to purchase the software, but I'm not sure one thing.
Can it (CD) be used on more than one computer, or must I have a dedicated machine?
ramal121
Calif Whine Country
You can use the original CD and license key to install the FPU on any number of computers. I have never read a license agreement from Kenwood to see the real legal wording, but I've looked on the CD and none is to be found. Does anyone know if it's on the dealer site?
avguy
NY, NJ Shore
I'm up and running.
The software is pretty straight forward and Wiscomm makes finding their cable drivers easy.
(if you discount the finding the com port name)
The only question that remains is will TK3300's without ProTalk talk to ones that do have it?
(If DT/DQT are the same and scrambling is off)
avguy
NY, NJ Shore
I now have three identical units (TK33004UP) the weird part is that one thinks it's not a ProTalk.
It will accept any frequency in the range with the programming software.
All the serial and model numbers are the same but it seems to have a different (newer) version of firmware than the other two.
Is firmware available to the public?
ramal121
Calif Whine Country
Again, the TK-3300 is a cross-over radio. Outta the box, it can be programmed by the user playing three card monte with the buttons and using the pre-programmed frequencies. When you hook up the radio to the actual programming software, you can disable this function, but you can also program any frequency and QT/DQT within the bandsplit that you desire including those provided by user button programming. Firmware has nothing to do with this...
avguy
NY, NJ Shore
I have the software.
( KPG -120D version 1.13)
With two of the units I am forced to select frequencies from drop down boxes.
The third lets me enter anything into a blank box.
Enabling or disabling the self program option changes nothing.
They also identify different when connected:
(1,2) TK-3300 Protalk [UHF]
(3) TK-3300 LMR [UHF]
ramal121
Calif Whine Country
Ok. For full programming capabilities, you'll have to change the model from protalk to LMR. Doing so will blank everything and you'll have to start from scratch (read and save an archive before you do anything drastic).
avguy
NY, NJ Shore
I've tried that, and it just produces an error when I go to write the unit.
"Check Model Name and Market Code"
