adamsc
I'm having issues being able to do Channel Select control from my console/dispatch to change the frequency to the TK7150.
They have 32 Frequencies, I am able to Tx/Rx/PTT over one frequency just fine. Now I am curious what pinouts from the TK7150 are used to be able to do channel changing from my Console. Right now my device can use Frequency 1 Signal/Com through Frequency 4 Signal/Com. from it's pins. Not sure where to match it on the TK7150 side though and what programming changes i would need to do.
I have set up the Relay Control to Binary and the Binary Relay Assignment starts with Freq 1 Relay Value 0, and ends with Freq Relay Value 31.
Any ideas would go a long way. Thanks
You can select up to 15 channels remotely using 4 pins on the rear connector.
It uses the Auxiliary Input Ports 1 - 4.
It would be difficult for me to describe it here, however there is some good documentation on this available. If you can private message me your e-mail address I can send you the info.
