Tk760H cloning, low power, squelch issues
sgillette159
I am trying to clone a pair of Kenwood TK760H radios. When I follow the procedures in the manual, the slave radio never shows the "-PC-" never appears on the screen. The master shows the "-C-" and the goes to "END" on the screen. Tried several times following step by step in the manual with no success.
Any ideas?
This radio is also an "H" model and is only putting out 21watts with brand new coax and antenna (tested, no short).
This radio also has an "open squelch" unless it is on the mic clip. Not sure if any of it is related.
Any ideas?
Been a while since I touched one, but usually the radio must be programmed to accept cloning.
How are you testing that? Test procedure will impact the reading.
Needs to have its squelch adjusted. Not sure if the programming software function allows that, or if you have to go into test/alignment mode. Either way, be cautious unless you have the correct test gear.
