TM9400 Problem
joescanner
Just another radio geek.
Gresham, OR
Radio has lost its programming (at a minimum). Try 1) reloading firmware 2) reloading calibration 3) reloading program.
W2GLD
Michigan
You need to open the Tx9000 cal tool, read the radio and write the calibration back, the database version is out of sync, you must have updated firmware and/or CPS
flametamer
Benton, MS EM42ut
The radio was in use and started showing the above. That's what is odd to me. No programming has been done since new.
Dt
W2GLD
Michigan
Dt
Then I would suspect it’s either got a hardware issue or it’s out of alignment.
