TM9400 Problem
joescanner
Just another radio geek.
Gresham, OR
Radio has lost its programming (at a minimum). Try 1) reloading firmware 2) reloading calibration 3) reloading program.
W2GLD
Southeast Michigan
You need to open the Tx9000 cal tool, read the radio and write the calibration back, the database version is out of sync, you must have updated firmware and/or CPS
flametamer
Benton, MS EM42ut
The radio was in use and started showing the above. That's what is odd to me. No programming has been done since new.
Dt
headsense
Member - Learner Driver
Generally you will only see this message after a firmware update and it is fixed by loading a basic code plug of some description.
As you confirmed though hardware problem in the torso or communication error/fault between head and torso.
