TRX-1 Activating SAME Standby Mode
dustoff813
I having difficulty understanding how to properly activate the SAME Standby Mode. The manual on page 57 is confusing.
Activating SAME Standby Mode: to activate SAME standby mode, press the WX key, use keys to find the best weather radio transmitter for your location, then press the SKIP key. This will change to STBY to indicate that SAME Standby Mode is active, and the scanner will alert when a matching SAME message is received. And SKIP = Stdby does appear at the bottom of screen with current NOAA WX broadcast being audibly heard not silenced.
then below it states...
To activate SAME Standby Mode: select a NOAA channel then press SKIP to enter Standby Mode. The speaker silences and SKIP = Normal appears at the bottom of the screen.
Do they both activate SAME standby?
