I set up TMS between a couple of XTS5000 radios as something to experiment with and so far it's been working well. I recently picked up an XTL2500 and it had the same packet data feature in the flash code as my XTSs so I wanted to give it a try between the mobile and portable radios. However, for some reason it doesn't want to work between the XTL and XTS radios. I've set everything up the same between the two and can only find two differences. On the XTL it is missing the options for Cached Credential User Login Mode and Radio ID Alias Enable in the Radio Wide -> General tab. And then in the Astro System I am unable to check Auto Generate IP Address. The option is grayed out. Of course I've tried manually setting an IP but I've had no luck.
My data users lists match and the TMS menu comes up on the XTL and seems to be identical to my XTS radios.
As near as I can tell everything is set up identical aside from those two things I mentioned. Has anybody had any luck getting this to work?
