danklibaner
Millstone NJ
first time programming. i am using the chirp program for my baofeng/pofung UV-82.
how do i tell the difference between a DTCS channel and a Cross channel
ladn
Are you programming for transmit/receive or receive only on a channel?
If it's transmit/receive, you may just want to set the DTSC (CTCSS) value on transmit to access the system and leave the receive value open. This will make it easier (especially when programming repeater channels) to verify you are getting through.
