Toronto Fire Training
fireuser
I'm using a Uniden BCD436HP to scan TFS from within the city. I can't seem to pickup any of the training channels. I have them selected and active in sentinel.
Looking for suggestions
Enjoi19
Ontario, Canada
How long have you been trying to listen to them? They are only active from time to time and sometimes training exercises end up happening on tac channels instead when it’s quiet or depending how long they are training for.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Make sure you have Fire Talk as a Service Type enabled in your Settings. They were in use last week.
Now that you mention it, I logged 1337 as a talkgroup last week. This would likely be TFS Training 4 which was missing in the database. (I have since added it.)
fireuser
Thanks for your responses. The setting for "Fire Talk as a Service Type" enabled - is that on the scanner or in Sentinel ?
Enjoi - I have a friend that can confirm the training channel
mciupa
Canadian DB Admin
Moderator
I'm here a lot
So to check by hand manually, push the Function and ZIP/SERVICES button. Scroll through to Fire Talk and Enable if it is off.
fireuser
Thanks again. I checked and Dispatch, Fire Tac and Fire Talk are all enabled. No joy
I'll keep trying
fireuser
Figured things out..
I still had "Project 25" in my Favorites even thought I had recently updated the database and written it.
Full write with new selection, and manually enabling Fire Tac and Fire Talk fixed the problem
I can receive the 6 training channels and talk-around now,
