BC125AT: Total newb BC125AT
OscarWill76
I just bought a BC125AT, and it says "all channels locked out" when I try to scan. Called customer service and very unhelpful.
My objective is to have the scanner go through all available frequencies to find stuff to listen to. Any help is appreciated.
Happy New Year!
D31245
See my Post #4:
If you are scanning your banks:
Try “Unlock all channels in Banks“ procedure at bottom of page 47 of the manual.
https://www.uniden.info/download/ompdf/BC125ATom.pdf
OscarWill76
Is it possible to simply scan all of the frequencies available to the scanner?
OscarWill76
See my Post #4:
I followed this, but when i preas scan, it again says "scan mode all locked!" When I press the scan again it says "all channels locked out"
D31245
Replying to your post #5…
Look under “Custom Search Mode” in the manual.
N6JPA
A Ham Radio Operator With too much frequency.
San Luis Obispo, CA
Have you programmed any frequencies into the radio banks? There is free Uniden Software to do this with in Windows. Once you have frequencies in banks then the banks will be unlocked.
OscarWill76
Maybe im using the wrong terminology.
I want the scanner to search through frequency 25 through 512, searching for frequencies that have people talking. It seems like when I hit "search,", it is going through 10 different banks, looking for any broadcast. Is that going through saved channels or is it actually "scanning" for any broadcasts, like I want it to do?
crippledchicken
Butler County MO
I'm not familiar with that scanner but found these directions maybe they will help.
Hold "func+L/O" a message should come up asking if I wanted to unlock all freqs, then press "E" for yes... Input several freqs in an unused bank and press L/O a couple times and then press "Unlock+E" (as per above) should unlock all the frequencies / channels
n1chu
Farmington, Connecticut
To add, scanning through all the frequencies 25MHz-512MHz will take forever and a day. (While the radio is scanning a different portion of the bands, activity on the other frequency’s wont be heard. So, the larger amount of frequencies you search will cause your chances of missing something. There’s an old saying that relates to scanner radios, “more is less”. If you want to search, consider reducing the upper and lower limits of that search. The other reply’s to your request for help suggest you study the manual (the easier to read manual). But sometimes that only confuses more when one is not familiar with the terminology. Radio Reference has additional forums, one of which is their Regional forums, listed by state. It’s a good place to start if you want to be able to sit with someone who knows the terminology and how to program. A word of caution… if you do decide to meet up with someone choose a public space with WiFi (in case there is programming that needs downloading and of course the Radio Reference database. In Ham Radio, we call those who mentor newbies “Elmers”. While I have no idea how they came up with the term “Elmer”, it’s obvious they are priceless when it comes to reducing frustration levels and learning curves. I’ve met up with quite a few, my most challenging was a totally sight impaired fellow who bought the SDS100. My first thought was “What was he thinking?” But he was determined to at least get some understanding of how to manage getting it to scan without any help, either from others or computer programs designed for the vision impaired. And he did accomplish operating the scanner with limited success.
OscarWill76
Ok, Im definitely using wrong terminology. On this scanner, I am "searching", not scanning. And I think I got it working.
Now just need to see how I can scroll through the saved frequencies. :)
N6JPA
San Luis Obispo, CA
If you want to search a frequency range then press the Srch key. If it comes up saying nothing to scan then press the 1 to 0 keys one at a time to activate the search banks. In the manual it will tell you the frequencies searched in each search bank.
OscarWill76
OK, figured out how to "scan" through all the frequencies, save frequencies that I hit, then scroll through saved frequencies or scan through them.
Definitely not getting as many hits as I get when I use the program function on CHIRP and my Baofeng radio.
OscarWill76
As I search through Bank 9 and 10, I get a ton of hits that are all static. Is there anything I can do to hear whats being broadcast? I see the scanner appears to have a search function for the security codes but I dont see how to make that work.
N6JPA
San Luis Obispo, CA
When the search of frequencies halts on a frequency then Press the Func key then press the EPgm key. A scrolled list will display and turn the knob on the top of the radio to select CTCSS/DCS then press EPgm key. Select the Search On option then Press EPgm key. It will search for the tones in all search frequencies scanned.
Whiskey3JMC
RTFF
Southeast PA 🇺🇸
These are likely digital frequencies (could be P25, DMR, NXDN & the like) You won't be able to pick these up with an analog only scanner (BC125AT).
OscarWill76
I dont see the CTCSS/DCS search taking place.
