Towers?
Where did this "tower" terminology come from? I was just reading about the Oakland CA system failure because of an overheated "tower". Last I recall a "tower" was an inanimate supporting structure for an antenna not an active electronic element. More of a rhetorical question I guess.
gewecke
Banned
Illinois
If you ever get the chance, ask to look inside of a tower enclosure or "shed" at the base of a tower. You'll see all kinds of racks of various equipment that are prone to overheating. Note the A/C installed in almost every tower shed you see. :)
73,
n9zas
SquierStrat
Fremont NE
yes, they probably meant the equipment using the tower is what overheated, not the actual physical structure itself. THAT would be some heat!
Yes I've been in the sheds. And up the towers. I am a former radio tech. :)
redshift
Eastern WA
I've seen an overheated tower. It took a lightning strike to cause the aforementioned heat, but it certainly was heat that was the problem. :D
mikegilbert
MHz so good
Los Angeles
I see a tower severely overheating in these images.
CCHLLM
Great pics. Top mounted amplifiers are sure necessities to make up for the signal losses in the 700 to 1200 MHz frequencies when there are combiner signal losses coupled with the feedline signal losses at the feedline lengths necessary with most towers, and the amps are always a joy for the firefighting profession when lightning plays unfairly or the amps go on a suicide binge.
Eldend
Fl
Cell Towers
It looks like three (3) different towers to me!
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Wirelessly posted (Mozilla/5.0 (BlackBerry; U; BlackBerry 9780; en-US) AppleWebKit/534.8+ (KHTML, like Gecko) Version/6.0.0.600 Mobile Safari/534.8+)
Deleted post
WayneH
Forums Veteran
Super Moderator
Your master site
And you never tried multiple times to explain what you did yet still got the confused look? :lol:
For some people the "tower" seems to encompass everything. "Ohhh, you work on the towers." :roll:
CrabbyMilton
If memory serves, there was a line in an old song that went to the effect..."Burning up the telephone line". So this must be the 2010's update to that song. See what happens when people can't stop talking on their phones. :)
Computer
I'm going to take a guess they were talking about a computer failed, that happened to be in a tower case.
Or they may be calling the equipment rack a "tower", and something mounted in the rack failed.
