SpringbrookTrails
So, a few months ago, I tried to wire up my Uniden BCT15X scanner in my 4runner. I was told that I should wire it to the accessory port on the fuse block. So, I did, and went away for a minute, came back with smoke pouring out of my dash. Unbolted the dash as quickly as I could, after yanking the scanner wires out of the fuse block, and sure enough it was the scanner burning up. It didn't do enough damage to fry it, but put out a good amount of smoke. So, after that, I haven't touched the fuse block. I ran the cigarette lighter plug behind the dash, and just ran it by that method. My questions are, #1, why exactly did it start smoking?, and #2, is there any way to convert the cigarette lighter to be an always on source? It will be on a switch if I do convert, but I'd like the radio to be always on, even outside of the car. Thanks in advance, I appreciate any help.
