TRC-459 help needed
press1280
I’ll check it out although I do not see any switches wired into the radio
press1280
Got the dongle and downloaded the software showing the frequency screen but it’s not working. Is there a video that shows how to easily set this up?
KEWB-N1EXA
Acushnet Heights Radio 740
Send us a link to the dongle you bought so we can help with it.
And what software are you using ? Dll file for the SDR Dongle and the USB port (zadig) software too.
press1280
KEWB-N1EXA
I'm running the Noo Smart SDR with HDSDR software...besides the Zidig USB driver for your computer you need a generic SDR DLL file
that you can select when you start your software if not it defaults to the Soundcard.
Hope this helps
KEWB-N1EXA
Hdsr.de is the program I have
Id check your spelling - I Googled it and checked a few web sites for (Hdsr.de) and found nothing with that name.
I you were trying to type HDSDR I can help you.
KEWB-N1EXA
Yes this is exactly what I have. I can’t figure it out. I’m to the point where I’d pay for software.
Ok
So you have the software installed
And you have the usb driver installed
You have down loaded the generic SDR DLL
File and put it in the the HDSDR directory
If you plug in the SDR into a USB port does it get detected?
Start the software does it ask for the dll or does it default to the sound card? If you talk at the pc mic does it show up on the screen as audio?
Go down the selections on the mid left side and select the input there you can select the SDR DLL file.
The whole thing should fire up at that point and your ready to go.
Let us know how far can you go before you stuck?
Pete N1EXA
KEWB-N1EXA
This is what it looks like to change the input !
press1280
RTLSDR (DVB-T/DAB with RTL2832) USB Is the file you need for the Noo SDR
[/QUOTE]
Ok I downloaded this and put into the hdsdr directory. A window pops up “Rtl devices was found but could not open. Used by another application or Zadig not installed?”
When I then click on the extIO button it says “ExtIO DLL not active”.
KEWB-N1EXA
[/QUOTE]
When you select the DLL in the input do you compete the path?
Basically HDSDR is looking for the file even if its in its own directory ...You must link it or show it the path to activate.
Also you can only run 1 Program at a time. Make sure you dont have 2 HDSDR's running...
Shown below are multiple copies of the same file just so if one gets corrupt...
if you select from the options ( INPUT) and select EXTIO you should get this prompt !
Pete N1EXA
press1280
It works!
Tried to transmit and I seem to be putting out signals all over the spectrum according to the SDR. Is that possible?
KEWB-N1EXA
It works!
Turn your gain down on the SDR your too close also you don’t need an antenna on the SDR being that close either.
Also transmitting into a dummy load would be better for testing purposes.
