TRC-459 help needed
KB4MSZ
Billy
Tampa, Florida
Is there a pin 9? According to the mod information that I have found for this radio pin 9 on IC1 is clipped off by the manufacturer. If it has been exposed and attached to anything then the radio has been modded.
press1280
I’ll have to look at it again. The top of the IC is a bit hard to see.
I checked each pin from the bottom of the board. I’m assuming since I got 6 volts across 9 and 18 that pin 9 is a ground.
press1280
HELL YEA!!!!!!
while I was looking closely at IC 1 I noticed something hanging out. It was resistor 16 right nearby. One of the leads had popped off the board. I didn’t think it would be the answer but I checked the resistor (within 5 percent of specs), rigged it up to make contact, and IT WORKS!!!!!!
Channels are all normal, used my walkie back and forth, all good!
Switched to 38 LSB, picking up a bunch of very clear chatter!
Thanks to you all for pointing me in the IC 1 direction!
KB4MSZ
Billy
Tampa, Florida
That is so cool. Not the problem I was expecting but cool.
prcguy
From your original description of the problem checking the truth table at the PLL chip would be one of my first things to check. Glad to hear the radio is working!
HELL YEA!!!!!!
