This is a prime example of small minded thinking that different is better. In 1998 the City was licensed for 10 frequencies in the 500 mhz range. They were just about ready to sign on the dotted line when a change in the PD administration caused a change in the plans, if the last guy thought a system in the 500mhz range was good, then we have to change and they went to a state of the art 800 mhz trunk-ed system that worked extremely well. The 500 mhz radios would have allowed the city PD to communicate with every other PD in the county, when they went to 800 mhz the City PD was an island to itself, could not communicate with anyone else, in or out of the county.
One positive of the 800 mhz system, even with all the tech specs put in the contract by the highly paid system engineers, the FD and PD demanded a simple plain language performance spec, specifically if a hand held unit could communicate with a unit on the street in front of a building, then it had to be able to communicate with the city wide communications center. Motorola initially laughed as they agreed to that requirement. Once the system was installed to the tech specs, the FD & PD tested the system to the plain language specs. An additional transmitter site was added, many satellite receiver sites added around the city. The system pretty much worked perfectly.
2015 - there are lots of questions, why not just replace the 15 year old equipment ? why start over again ? At this point, 2019 I do not think the City is even the license holder for the frequencies they use now. They bought or leased equipment to work on MPS's frequencies and towers, except the system sucks.
Some agency needs to investigate ........
When I started working in Trenton the chief of police was a policeman. After he left they went to police directors. There was always some kind of a scandal or questionable situation with officials, especially with the school district and the police.
The UHF system they were using along with all the other municipalities and Sheriff's Department allowed everybody to talk to everybody else in Mercer County.
When Trenton went to the 800 megahertz system in 2000 we could no longer pick up police on scanners but they continued to rebroadcast on their main UHF Channel for a while, then pulled the plug. The fire department also was rebroadcast on the original UHF F1 frequency and still is to this day.
That's when my good relationship with the mayor paid off, he had the police department give my newspaper one of their Motorola radios disabled for transmit, at that point I had been promoted to Chief photographer and was able to carry that radio. Bucks County had just gone over to their type II smartzone digital system and we had to use Motorola's for them too as digital scanners were not developed till 2003.
Mercer county was building their 500 megahertz digital system at that time and Trenton could have been part of that and although they were licensed for it, never got involved. Only two police departments in the county got involved with that system and all the other Department stayed on their UHF frequencies except for Ewing who went to a p25 encrypted system.
The county still maintains the Mercer County Crime Alert Channel on 453.225 pl 103.5 which Trenton doesn't have. They are also not on the State Police emergency Network which all police departments are on in the state.
Why Trenton got the nxdn system with MPS I have no idea. When the system went online we got the frequencies from public listings under the name of MPS Communications and the City of Trenton's name wasn't on any of it. We fed the frequencies into DSD and was able to pin the system down pretty quickly on laptops in the car and at home. That was around 2015.
I guess the point is in the last 30 years Mercer County went from a very compatible police radio network allowing direct communication between all departments to a mish-mosh of a various systems. Where was the planning? Obscene amounts of money spent.
And yes, why did Trenton go with MPS Communications? Who knows?
I smile when you say there should be an investigation by some agency and you are absolutely correct, exactly though, who would do that investigation? LOL.
