Treport Help
scannerfreak
Well Known Member
Indiana
I am trying to run treport in Windows ME Dos. I am getting a "Can't Load File Treport.INI" message..The INI file is in the folder along with the exe and I configured it..Anyone have any Ideas on what the problem could be?
scannerfreak
Well Known Member
Indiana
Bandit,
Thanks, but it still tells me Can't open file treport.ini...It won't even load the program...Any other ideas?
PS- Trunker is working fine...
joepaigejr
Lorton,VA
What directory are you running treport from, and what directory is treport in? Also, how are you getting to the DOS prompt?
scannerfreak
Well Known Member
Indiana
It is in my C directory, I am using ME and going to the DOS prompt and typing:
start C:\tr282\treport.exe
It works this way for trunker and use to work this way for treport as well...But treport just all of the sudden stopped working...Thanks.
joepaigejr
Lorton,VA
Try typing:
command
cd \tr282
treport
Also, when you run trunker, do you use the executable or a batch file?
scannerfreak
Well Known Member
Indiana
I am running the exe on trunker, and that didnt help treport any...Thanks
BANDIT
Gainesville, Ga
Do you have treport.ini in the same directory as Treport.exe. Its not like trunker which reads the trackenv.txt file in your root dir. Treport.ini has to be in the same location as treport.exe. :shock:
scannerfreak
Well Known Member
Indiana
Yes, it is in the same folder...thanks
Rick, Wayne..Please help me! :D
*beep*
Thank you for calling the Treport Help Line. Your call is very important to us. Please hold ... Wayne will be attending your question shortly. Please stay on the line.
While you're waiting, we'll be playing live streaming audio of the Walt Disney World trunked system control channel for your enjoyment.
*beep*
Seriously ... I'll take a look. Is the INI file by any chance marked as "read only" ???
-rick
scannerfreak
Well Known Member
Indiana
:lol: :lol:
Thanks for the reply Rick! I did check that and it is not marked read only..This is really driving me insane! Any other ideas?
WayneH
Forums Veteran
Your master site
Is there a TREPORT.PIF file in the directory not correctly pointing to the EXE? (Like if you moved Treport to a different directory and copied the contents) Even when you dbl-click the EXE it automatically looks for a PIF file first.
This is the first I've heard of this.
-Wayne
scannerfreak
Well Known Member
Indiana
Wayne,
I can double click the exe and treport will open..It's only when I try to open it in DOS do I get the "Can't open treport.ini file"..I'm not sure about the .pif file..I do not see that file along with the contents of treport when I downloaded it..Where would I find that file?
I'm thinking maybe I will just create a DOS partition on my XP machine and see how that goes!
Thanks for your time and help!
WayneH
Forums Veteran
Your master site
Did it ever work in ME? If not, then get away from it. Most be some DOS/ME file access issue or something ridiculous. I really have no clue.
I don't see why people run TREPORT in Windows anyway. You can't multitask with it well. Stick with straight DOS people and it will work like it's supposed to. I don't like supporting Windows users as Windows causes too many stupid problems.
-Wayne
scannerfreak
Well Known Member
Indiana
-Wayne
Ya it did work at one point in time Wayne, However, I agree with you..I'm going to use it like it was intended to be used..I am going to create a DOS partion! Thanks for the help,
Steve
