Trinity EMS Torrington
cg
Connecticut
55engine
Hartford County area
I did download it but I can’t find it and it will not show up on my screen but it keeps saying about net framework
PurityControl2
For anybody else still having issues receiving Trinity in Torrington with a BCD436/536HP - I was able to fix it by manually programming a new system as "DMR One Freq" with the three Torrington site freq's & color code of 9. Sentinel does not allow inputting LCN's that I know of or can see with the One Freq option, however I am receiving voice from Trinity now after making these changes.
Mork
Connecticut
In developing the Tier 3 firmware, I need to confirm the TG TrinityDMR.
can someone affirm that the post the rr db is correct
PurityControl2
The RRDB as far as Torrington is listed is correct. I can't vouch for the other talkgroups.
6685973TTrinity TorrTrinity EMS Torrington
cg
Connecticut
Works fine with updated Uniden firmware on 996P2, should be the same issues that they fixed for that radio.
6685973 - Torrington
6685974 - Waterbury area
6685976 - Hartford
6689676 - Hunters
Couple other very busy groups that are heard on Talcott site:
6691273 - Bus company
6691473 - Greater Hartford Transit District A
6691474 - Greater Hartford Transit District B
6691475 - Greater Hartford Transit District C
6691476 - Greater Hartford Transit District D
firerick100
wolcott ct
I just saw on Facebook post that they released firmware update for the sds radios
it says it supports DMR tier 3 multi block VCH grant
improved to detect DMR tier 3 capacity max late entry messages
now that this update, will we hear trinity in Waterbury now on a sds 100
thanks
seagravebuff60
Short Bus Reject
Just updated the firmware on my SDS200. I'll check back later to see if it received anything. So far no luck yet.
seagravebuff60
Short Bus Reject
I am picking up this system better than I was previously with my SDS200 after the update. But still nothing on the Trinity TGs, but i may just be to far away. I receive them loud and clear on DSD+, but the SDS struggles sometimes. I'll have to check my programming on the SDS as well.
Yes, we should be able to do so after the new firmware update on the SDS series.
55engine
I was picking up laz yesterday, which I never picked up before in BRISTOL, but I updated all my radios system seems to be doing a little better
Mork
Connecticut
I have the latest firmware in my SDS200 and 100. When I hold on Homeland Defense Network, I still can’t hear Trinity Amb in Torrington. I’m in New Hartford. The tg is in there. It’s set for ID scan. What do I have set incorrectly?
cg
Connecticut
What SIte do you have programmed?
What do you have programmed for frequencies and LCN?
What do you have programmed for talkgroups?
seagravebuff60
Short Bus Reject
Im having the same issue with my SDS200. Ive only been able to hear them with DSD+ off the Wolcott site. My SDS struggles to get the Control Channel, while DSD+ gets it 5x5 like it is in my backyard. If they are in the area, sometimes I hear them on other sites, too. It all depends on affiliations.
I just created the FL from copy and paste from the main db Homeland Defense Network Trunking System, Various, Connecticut
What Site did you program? Do you have the "EMS Dispatch" Services tag on? Can you sit on the Control Channel frequency and hear the Control Channel of the site you are monitoring? Are you hearing other activity on the system and just not trinity?
