Trinity EMS Waterbury
firerick100
wolcott ct
Does anyone have a sds100 and are able to listen to trinity EMSin Waterbury, they are on the homeland system and I do have the DMR key and 2 local sites with the talkgroups programmed but unable to get any voice on the channels. Thanks for any info
ems170
Connecticut
They will typically operate on the Wolcott or Waterbury sites. They should be programmed as a DMR TIII system. I have had good luck hearing them with the following settings, which have been verified via DSD
Waterbury:
Wolcott:
cg
Connecticut
Rick, what do you have programmed for LCN and do you have the latest firmware?
ems170
Connecticut
That's a great point, CG. Decode was pretty ehh, until the last FW update with whith the late entry DMR fix.
firerick100
wolcott ct
I have all the freq for wolcott & Waterbury site that are posted above.are they using color codes that is shown above ? I thought I downloaded right from the software last year but possibly did it manually
firerick100
wolcott ct
The
I just downloaded the latest after reading you comment.
main is 1.25.01 and sub is 1.03.15
firerick100
wolcott ct
Waterbury:
Wolcott:
I only have DMR one frequency in drop down the one you mention is not there
firerick100
wolcott ct
Waterbury:
Wolcott:
Ok so I updated firmware in scanner then I did figure out the dmr tier 3 and put in those frequencies with color codes and lcns in 2 sites as they are in your picture so now we will see if I can pick them up, although the post shows actual talkgroups in the data base and It doesn’t have that function when programing, ill let you know if this works and thanks
ems170
Connecticut
You're welcome. Those were confirmed with DSD, the TGs in the database appear valid, and I can't fully attest to the labels used. Good luck
