Trouble programming LTR sytsem in F4061S
medic77083
Houston
New to the radio world and forum, but I'll give this my best shot explaining my issues.
I have the 1.2 version of the IC-3060 software that seemed to have been working fine. I have the radio set to LMR/LTR, and my conventional banks operate fine. Now the issue begins.
I have a work system I'm trying to program, but I have no idea how to properly program in the talk group IDs. They are listed as such:
0-01-101 A TC Dispatch
0-01-102 A TC GuestSvc
0-01-106 A TC Maint
0-01-113 A TC Fac Maint
0-06-101 A TC 24-hr Sec
0-06-102 A TC Housekpng
0-06-109 A TC Catering
0-06-110 A TC Media "
My other issue is, when I attempt to load in a profile from a coworker's same radio model, even with regular conventional banks programmed, my radio reads "EMPTY" when it powers back up. When I try to copy the LTR data into my profile, the first bank is the trunked system, and will flash the screen and play static, and when I switch banks the radio ignores the bank completely until I recycle the power.
My radio is a 4061S, 400-470 w/UT-119 board installed, same with my coworker's radio. Any help to get me pointed in the right direction would be greatly appreciated.
medic77083
Houston
added you on AIM, but havent seen you online. I could still use some help with this, if anyone has any ideas. thanks.
medic77083
Houston
Pm sent, thanks guys.
Also, does anyone make a 2-pin adapter for this radio? The headset I want to use with this is the older 2-pin style, and I know motorola makes an adapter for it, but cant find anything for the Icom =(
gmrsoutlet
Oswego, IL
Icom makes an adapter, the AD52.
However I belived it is for listen headsets only, and does "break" the IP55 rating when in use.
