Trouble Programming :(
highstupid
Banned
Wellington County, Ontario
Hi all,
I have an XPR7550 and I am trying to program it via cable, but having no luck. Cable says IMPRES Accessory when connected to the radio, and connects properly to Windows 7, but I cant seem to read or write to the radio.
At a loss, any help appreciated!
gtaman
GALAXY 19 91.0° W
Hi all,
Did you install the driver and the appropriate CPS for the radio?
dmaria
Hi all,
I believe the correct driver is installed with the CPS. I have an XPR7550 that I program using Windows 7 and 10 with no problem. If you haven't installed CPS, you won't be able to program the radio.
Added: The cable contains no USB components. The radio is the USB client - not the cable.
