Truckee Meadows Command Channels
Car233X
Seasoned
Northern NV
I have noticed that when TM switches up to Command 1 or Command 2 for responses I usually only hear them on the VHF side and not on EDACS. The normal steps have been take, correct TGID etc. Anyone have any ideas?
markclark
Nevada Range
I have:
TMFD Command 1 030-62
TMFD Command 2 03-163, And a whole bunch of TAC trunking Talkgroups.
It is very common for TMFD to use VHF for wildland fires. In fact, if a wildland fire occurs you can bet on TMFD going to VHF. I downloaded all the frequencies and Talkgroups from RR.
Are you monitoring the Washoe County Metro system?
Car233X
Seasoned
Northern NV
No the McClellan site on the EDACS side. I’m a bit too far south for the Reno Simulcast, Slide or Washoe P25. This is for major crashes and reported structure fires. Previously Command 1 and 2 on the trunk side simulcasted to VHF.
markclark
Nevada Range
I hate to tell you this, but McClellan is a fill-in site with real limited coverage. Not only does it have a small footprint, but it probably won't carry all the traffic on the Metro system or Slide Mtn.
You may need an outside antenna, perhaps a Yagi type, and see if you can receive Slide.
Good luck !
fsa3644
David H
Carson City NV
in Carson on WC Slide i get all Truckee Meadows channels just fine. Ill try out McClellan. Never tried the Pinenut site or VHF.IMG_8565.jpg
markclark
Nevada Range
You'll receive Pinenut well in Carson City. The OP, doesn't appear to be in Carson City so he can't receive Slide Mtn.
