trunk recorder error
dave3825
Suffolk County NY
Keep getting this on 16.4 lts that was last ran a year ago and worked..
Using device #0 Realtek RTL2838UHIDIR SN: 00000001
Found Rafael Micro R820T tuner
./recorder: symbol lookup error: /usr/lib/x86_64-linux-gnu/libgnuradio-osmosdr.so.0.1.5git: undefined symbol: rtlsdr_set_bias_tee
Any idea how to fix? I am not using bias tee nor a dongle with one.
boatbod
Talbot Co, MD
I'd say the version of trunk recorder you are using was built against a different version of libosmosdr.
How to fix... well that depends how you installed the software :) Might be as simple as a "sudo apt update && sudo apt upgrade" or it may take more work to track down the correct versions.
dave3825
Suffolk County NY
I had installed Op25 , trunk recorder lighttpd and gqrx all around the same time like 2 years ago. Got sick and put it all on hold but when I stopped using the raspberry and linux laptop, all was working. Fired both up today and op25 boatbod worked flawlessly but could not get trunk recorder to load past that error. I am pretty sure I did sudo apt update & upgrade but will try again. My Linux is very rusty and I also need to change the port in the lighttp.conf file and it keeps saying access denied. Will try update and upgrade again. Thanks
