Trunk-Recorder - Loud Random Static
CCTX
Wondering if someone has encountered this before. At random times I'm getting a very loud static noise almost like it's trying to decode an encrypted stream or a data channel. This shows up on different channels on valid TG's so I can't just mute the TG. The logs don't appear to show anything out of the ordinary. Is there a config option I've missed to filter these? Anyone else run into this?
Here is the decode log.
Code:
[2022-01-21 15:33:35.012884] (info)   [warrs]   61C     TG:       2001  Freq: 853.362500 MHz    Starting P25 Recorder Num [0]   TDMA: false     Slot: 0 QPSK: true
[2022-01-21 15:33:35.625116] (info)   [warrs]   61C     TG:       2001  Freq: 853.362500 MHz    Starting new Transmission       Src ID:  91130
[2022-01-21 15:33:44.003669] (trace)   [warrs]  61C     TG:       2001  Freq: 853.362500 MHz    Stopping Recorded Call, setting call state to COMPLETED - Last Update: 4s
[2022-01-21 15:33:44.003736] (trace)   [warrs]  61C     TG:       2001  Freq: 853.362500 MHz    Concluding Recorded Call - Last Update: 4s      Call Elapsed: 9
[2022-01-21 15:33:44.003761] (info)   [warrs]   61C     TG:       2001  Freq: 853.362500 MHz    - Transmission src: 91130 pos: 0 length: 2.88
[2022-01-21 15:33:44.544975] (info)   [warrs]   TG: 2001        Freq: 8.533625e+08      Broadcastify Upload Success - file size: 20259
This is the audio from the above log.
Link to audio clip for reference.
wtp
Port Charlotte FL
how close was a cell phone ?
my uniden 396T and XT do that when too close to a cell phone, it does sound a little digital from here.
yearrs ago i had turned my squelch down to 0 on the T thinking it would pick up lower signals and it would do the random noise thing even when not near anything. (out in a yard)
CCTX
The antennas all sit up in the attic and I get pretty terrible cell reception out here. I wouldn't think it's cellular but that's not a bad idea. The only thing close by is the air handler. Maybe that might be interfering?
I can try to add squelch to the config but I thought that was for conventional systems only.
edit: cell reception
wtp
Port Charlotte FL
and the worse call reception you have the higher the output on the phone.
if i recall there are 8 power levels on a cell phone.
i wound usually not blame the air handler, but now everything has a computer chip in it.
gotta go i think my toaster has a call for me.
