Trunk-Recorder - Upgrading RaspberryPi to V5.0
kd4e
Nevils, GA
So, I just install over the top of what's there and it won't overwrite the config.json, tg, etc?
Or, do I start with a fresh RPi 64 micro-SD and do a fresh install - then copy over config.json, tg, etc?
Note: This one is a local-only install, plus rdio scanner, so it's pretty simple.
Thanks!
PacScan
Los Angeles
What I did is leave my existing folders alone. Stopped and disabled the v4 service. Installed fresh under a new v5 folder, then copied the configs over. Started a new v5 service
kd4e
Nevils, GA
Not sure if there's a lag in updating the Forum (when replying via email) or what, so I'll re-post my reply ...
Just to confirm - you, also, are not using Docker?
Thanks.
kd4e
Nevils, GA
OK, cool, I should be able to take a run at this tomorrow ... after my morning coffee, of course. Thanks again.
