TRUNK88/396xlt Help
tbrady
I'm trying to setup my bc396xlt to run with TRUNK88. I can't seem to get it to work.I keep getting a two tone beep with a message, "can't open master file" etc. Please help. Thanks Tony.
check the comport in the s/w to the ones in trunk88 se if they match up, also try ugplugging the cable & reinstall drivers THEN plug it all back up
joescanner
Just another radio geek.
Gresham, OR
Make sure you are running Trunk88 from the directory where you installed it, and that TRUNK88.CTL exists in that directory.
Once Trunk88 is running, hit ESCape to enter command mode then go to D)efaults choose I for Input (Control Channel) Parameters, and down-arrow to "CC Data Serial Port" and set that to the number (as in COMx:) of the port your scanner is configured to.
Press Ctrl-F2 and see what happens.
wvscanner
Beckley, WV
I don't want to sound like a broken record but, does Trunk88 support apco 9600 system since it is reading the cc dump on a uniden XT scanner?
tbrady
TRUNK88 still not working
I can open up TRUNK88 from the desktop and access the Command Prompts no problem.I enter the default settings for CC decoding then CTRL F2 and nothing happens.The program shuts down on its own,crashes my computer with the Blue Screen,any help? Thanks Tony.
DaveIN
Founders Curmudgen
West Michigan
Did you verify what port is being used via device manager? You need to make sure it uses the correct com port is set in the configuration file, and is also set for control channel data input and not sound card input.
The blue screen of death sounds like a port conflict crash.
slicerwizard
Toronto, Ontario
TRUNK88 doesn't run with the privileges required to force a blue screen. This user's problems are caused by the buggy Prolific drivers that came with his Uniden USB to serial cable/adapter.
Back on June 15th, I sent an updated TRUNK88.EXE that works around those bugs to his Yahoo email address, but have received no response from him.
tbrady
TRUNK88 setup help
I managed to get it running with limited results without crashing or shutting down,at your convenience could you please resend me the updated TRUNK88 EXE file.I did not receive the previous update from June 15,thanks.Tony.
