81buckeye
Noticed in the db configuration that I imported and uploaded to my scanner, that for a re-banded Motorola system (Motorola Type II SmartZone-Analog and APCO-25 Common Air Interface), that all frequencies associated with this system were listed including control channels). But the selection in the scanner configuration was "control channels only". Does this present any problems?
In other words, if using setting as "control channels only", should only the control channel frequencies be listed? Or is better to enter all frequencies, and and not set "control channels only"?
Reason, I am asking is that I am not receiving any transmissions from this system, even though everything else seems to be correct. The re-banding info is entered as well?
Help??
Help??
