Trunking Hang Times
WayneH
Forums Veteran
Super Moderator
Your master site
A repeater? No. There are variances in hang time when comparing message versus transmission trunking. With message, after the subscriber unkeys, there is a very slight hangtime while the system holds the subscribers on the voice channel. With SmartZone you can control that amount of time. With transmission trunking once the subscriber unkeys the conversation immediately ends and the radios go back to the control channel.
Then there's also PTT trunking which is similar to message trunking but any replying radio must return to the control channel to be authorized before replying to the original conversation (the voice channel won't change frequency either).
These modes are programmed in the system and radios.
-Wayne
wavetar
-Wayne
You can also control it in SmartNet & Privacy Plus systems as well, under the PARM command in the controller.
Todd
