Trunking System Question
mocofeed
I have a Unication G3 with the 450-512mhz UHF band.
Will it work with the West Virginia Statewide Interoperable Radio Network?
There are a handful of sites out of that band, but not the ones I want to monitor. I wasn't sure how this worked, so I wanted to ask the broader group. WV SIRN is linked below.
When you import the system into the C1 tab from Radio Reference you may not import SITES 1.31, 1.49 and 3.60, these are all out of band. If you do NOT un-select them before you import them then the system will not appear in tab E2 when you try to add the system from the Resource Manager, as mentioned in your original post on the same topic (something discouraged in the forums).
mocofeed
When you import the system into the C1 tab from Radio Reference you may not import SITES 1.31, 1.49 and 3.60, these are all out of band. If you do NOT un-select them before you import them then the system will not appear in tab E2 when you try to add the system from the Resource Manager.
Unfortunately that also did not work. It's still not showing among the options to import.
This is above my head, but I know these are out of my unit's band split. Can someone explain? Mine is 450mhz to 520mhz
SIRN P25 Channel ID Table
CH ID Type Base (MHz) Spacing (KHz) Transmit Offset (MHz)
4 FDMA 450.00000 6.25 +5
5 FDMA 400.00000 6.25 +9
6 TDMA 450.00000 6.25 +5
7 TDMA 460.00000 6.25 +5
That is the table, not frequencies used, ignore that and see comment in your duplicate post (something discouraged in the forums)
Then the trunking table may be what the import manager in the PPS is looking at, and it won't work. Maybe someone from WV will have more information on it.
lebrunmn
Retired... Get off my lawn!
Hampshire County, WV
I use FSS when I travel out of my home area, and it works just fine with my G3 (which is an older, pre-DMR version). FSS works great for me. I use this freq range:
