TRX-1 Error 5-00
cortman
I am a newbie to the forum world and to scanners. My scanner was working fine and I'm sure I changed something and now I have an Error Detected message. Please see user guide for more information. Code 5-00. I bought a new card but the message is still on. I could use some assistance.
gh6406
Dalton,Ga
That is a SD card error. If you have a New SD card, install it. Connect scanner to computer. Then from EZ Scan software, click the Scanner/SD Card option at the top. Then click on Prepare Scanner memory/SD card for use. This will format the SD card and install necessary files on the card. Then copy configuration to SD card.
Hope this helps.
cortman
Thanks for the reply. That worked and I really appreciate the quick response.
