TRX-1 Trunk. Programming
NP3Z
Utuado,Puerto Rico
HI , I already have some trunked system into my trx-1 from a file sended by a friend. Want to add some new ones that i found over the internet . Using EZ Scan Software I add the system,sites,frequencies ..after all done I can not find the system in scan list , how can i asign or add the system to a new scanlist (empty one)? Many thanks for the help.
gmclam
Fair Oaks, CA
When you add the system, you should also add talkgroups. You then assign the talkgroups to a scan list. At the very least you can use a wildcard talkgroup to receive "everything".
Ubbe
Stockholm, Sweden
It is only the talk groups that can be placed in a scanlist. Look at the far right on the line for the TG number and name and there you set the scanlist.
/Ubbe
NP3Z
Utuado,Puerto Rico
When I go to add talkgroups i add Wilcard! it pops up a list with al the scan list including the one in use and empty ones so i can click in a empty scan list and them rename it an all set? thanks
