TRX-1 upgrade error
B-Parker
Hi I put my trx1 into firmware upgrade mode and it has come up with
up boot ver: F1.3
up app :ver NONE
cpu sw upgrade:
ERROR -Turn off
I can not get it to turn off even removing battery and usb it fires up with same message.
any help would be very much appreciated.
when trying to download a file to try and sort it from whistler i get
Not Found​
The requested URL was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
buddrousa
Whistler Site has been down for over a week a check of the forums would have shown that.
Point 2 I am not sure how to get out of the update mode without the site being up and running others here may chime in with an answer.
B-Parker
Thank you very much. I'm new to whistler so I wouldn't know is it a common problem the site being down.?
tvengr
Well Known Member
Baltimore County, MD
You have lost the CPU firmware. Here is CPUUpdater_TRX-1_U5.9 to get your scanner working again. Save the attached zipped file to your computer and extract. Connect your computer to your scanner and run the updater. For safety, I downloaded all of the updaters from the Whistler site before it went down again.
  • CPUUpdater_TRX1_U5.9 (1).zip
beaulattery
B-Parker
Hi tvengr I ran it and got another error im going to look error code up but wanted to acknowledge that I got your file Thank You.
tvengr
Well Known Member
The scanner needs to be off when you update it. Make sure you are using a data cable and not a charge only cable. Hold the MENU button while plugging the cable into the scanner.
B-Parker
A BIG Thank You tvengr its up and running again I took the sd card out and put it in my laptop loaded it and put it back in my Trx-1 would you know how to upgrade to TRX-1E ? I'm disabled from a head injury and by the time I've watched YouTube I've forgot what it said and find reading instructions like you just did for me I can do it much easier. Any help is very much appreciated.
Bill
