This expands on what N1GAW just posted. There are separate TRX-1 and TRX-2 apps. You know that the TRX-2 works OK. To ensure that both scanners have the same programming, use the following procedure: Connect your TRX-2 to the computer. Using the TRX-2 app, click on Scanner/SD Card tab and Copy Configuration from Scanner Memory/SD Card. If it asks to continue, click Yes. Click on File tab and Save Current Configuration to Archive. Give the file a name, other than the CDAT number, and save. Connect your TRX-1. Using the TRX-1 app, click on File tab and Restore Configuration from Archive. Click on the file you just saved and Open. When it asks Continue with Restore?, click Yes. Click on the Scanner/SD Card tab and Copy Configuration to Scanner Memory/SD card. You now have the same exact programming in both scanners. What do you want to monitor? Include system, county, city, and state.
