prcguy
- Joined
- Jun 30, 2006
- Messages
- 17,658
- Reaction score
- 12,994
The whips on these cheap mag mounts are thin piano wire and after 30 seconds of key down at 25w you will burn your finger touching the whip. The steel is lossy at VHF and there is too much RF current for the wire size so the whip cannot dissipate the heat generated over its length in that amount of time.
Or do you know of something else that would explain the heat?
"...I have some cheap 2m/70cm mag mount antennas with whips made from thin black coated steel wire and they get hot at 25 watts because steel is not a good conductor for antennas. "
I think you said the problem with that 'cheap' thingy. Steel will handle RF/power just fine. If it gets hot then look for another problem.
