Why would they be moving to UHF? Is Federal VHF really crowded in some areas?
Yes, plus 400 MHz will travel well in corridors.Why would they be moving to UHF? Is Federal VHF really crowded in some areas?
what about the Louisville Ky and the Lexington Ky. what about the knoxville area
And... UHF has far less tendencies to play with the electronics and avionics of aircraft. One of the reasons that "most" businesses involved with airports all use UHF. While yes, VHF does tend to propogate better at longer ranges, it for some reason does NOT play so well with the systems on aircraft. (At least those in FM, possibly another reason why you won't see FM in use in commercial aircraft.) Military aircraft, and US Government aircraft do use FM rather heavily in comparison. Possibly better shielding? (I have always wondered about this since they always use that as a trump card when it comes to radios and scanners on aircraft...)Yes, plus 400 MHz will travel well in corridors.
i don't know because they don't have no record on the radio reference database
I can confirm at least TSA BOSTON is P25 encrypted.
Can NOT confirm what freq though.
I am retired TSA Supervisor, all our radios are encrypted, as of 2018 when I left
Not being a jerk, but the only thing you can confirm then is in 2018 everything was encrypted. Things can and do change.
Back when TSA was not ALL federal employees sworn blah blah.... And they still had contractors doing things.. Yes, the contractors were in the clear on analog even, and the "actual" TSA folks were mix of clear and encrypted craptacular analog (yes analog is crap when encryption is applied), and P25 clear and encrypted. From what I gather, there are NO contractors doing TSA stuff anymore, and there is only maybe a very very few analog radios even in the stockpiles anymore. (Yes the P25 ones can do analog if programmed for it, and DO have the analog interop freqs programmed in them, but don't count on those EVER getting used b y TSA!) Now 99% of the TSA is fully Federal employees and uses P25 almost exclusively, and yes "mostly" Encrypted with some in the clear. (If Homeland Security heard them not encrypted, there would be NASTY memo's going to folks from D. C.!)
Lexington is still VHF as of 1/12/23, and Louisville as of the Kentucky Derby according to my notes. Can't speak to Knoxville....what about the Louisville Ky and the Lexington Ky. what about the knoxville area
